Sep 29th, 2024, 8:20am
papers/patents on low pass filters (Read 5219 times)
jlee
Jul 12th, 2008, 11:32pm
Hi Guys,
I am searching papers/patents on low pass filters with very low -3dB frequency.
In order to decrease chip area, small capacitance and large resistance are used. The resistor is implemented by MOS transistor operated in subthreshold region.
Does anybody know the detail information about these papers or patents?
Thanks for your feedback in advance.
Jason Cheesy
buddypoor
Bremen, Germany
Re: papers/patents on low pass filters
Reply #1 - Jul 13th, 2008, 1:58am
As your mosfets are operated below threshold (weak inversion) I understand that you are interested in information about log-domain filters. Is this corect ?
jlee
Reply #2 - Jul 13th, 2008, 5:51am
Thanks for your input, buddypoor.
What's log domain filter?
Actually, I am realy interested in how to implement a large resistor, say 10M ohm, with MOSFET operated in subthreshold region. I just want to search some papers or patents on this subject to get some design insights.
Jason
buddypoor
Bremen, Germany
Reply #3 - Jul 13th, 2008, 6:54am
Well, here is some background information about log-domain-filter:
With the aim to lower supply voltages and power consumption, it is possible to use MOSFETS below threshold (weak inversion) using their nonlinear properties and to correct the introduced distortions thereafter.
This is something like compression/expansion (companding) and is applied exclusively in integrated form.
But I´m not sure if you have asked for such a modus to provide active filtering.
lightgo
Reply #4 - Jul 14th, 2008, 6:34am
Is that Yong?
if yes, you can login Bo's computer and find the documents you want on the desktop. Smiley
solidstate
Munich, Germany
Reply #5 - Jul 15th, 2008, 11:18am
I've used this successfully:
J. A. Geen, S. J. Sherman, J. F. Chang et al., “Single Chip Surface Micromachined Integrated Gyroscope With 50°/h Allan Deviation,” IEEE J. Solid-State Circuits, Dec. 2002.
Reply #6 - Jul 15th, 2008, 5:25pm
Tsividus is the well published whiz kid on what are known as "MOSFET - C" filters.  Google it or look in IEEE JSSC or IEEE Xplore- they do lack dynamic range and have linearity issues, but they are a useful methodolgy in some cases.
A quick look shows about 50 papers on the IEEE Xplore search
Jerry
jlee
Reply #7 - Jul 16th, 2008, 10:30pm
Thanks! I'v got the information from your inputs
