Sep 29th, 2024, 8:23am
MOS Cap region of operation (Read 3365 times)
AnalogDE
Jul 14th, 2008, 10:50pm
MOS Caps can either be operated in accumulation or inversion... What are the pros/cons of each?
neoflash
Mixed-Signal
Designer
Re: MOS Cap region of operation
Reply #1 - Aug 16th, 2008, 9:48pm
MOSCAP in inversion region is more stable with frequency and is lower in loss.
Accumulation region capacitance will reduce with higher frequency. Also the loss is higher.
vivkr
Reply #2 - Aug 17th, 2008, 10:58pm
neoflash wrote on Aug 16th, 2008, 9:48pm:
Hi neoflash,
I would have imagined the reverse to be true. Atleast the textbook model shows you 2 curves for the inversion region, the high-f and low-f ones, whereas for accumulation, this is not the case. Are you considering the losses due to the parasitic resistance etc. that come into play with the accumulation cap (which the textbook does not consider)?
Vivek
nano_RF
madison
Reply #3 - Aug 20th, 2008, 8:18am
I am also of the opinion that in accumulation MOS cap is more stable then inversion mode.
About the loss not sure but I guess the bottom layer is a p-type (hole) conduction in accumulation as compared to  an electron conducive (NMOS Cap assumed) with electron reservoir (n+ regions) in inversion mode. So it could be lossy but still not positive though.
