Sep 29th, 2024, 6:21am
Unity Gain Frequency(and filters) (Read 9385 times)
Turin
Greece
Jul 28th, 2008, 8:10am
This might sound a silly question but i'm a little mixed up at the moment...Let's say we have an intergrator with a certain unity gain frequency.If we had a Gm-c filter with this intergrator how would the unity gain frequency relate to the filter frequency.Would it be the same or would just be depened on it in a cetain way...?
buddypoor
Bremen, Germany
Re: Unity Gain Frequency(and filters)
Reply #1 - Jul 28th, 2008, 9:13am
Well, a general answer cannot be given since it certainlydepends on the filter order and topology. However, for a second order stage very often the pole frequency wp is identical to the square root taken from the product of the integrators unity gain frequencies.
Turin
Greece
Reply #2 - Jul 28th, 2008, 9:26am
What i had in mind is an elipictal 3-rd order Gm-c filter
buddypoor
Bremen, Germany
Reply #3 - Jul 28th, 2008, 9:38am
OK, but what is now your question ? I suppose you have a circuit diagram and corresponding formulas, donīt you ?
Turin
Greece
Reply #4 - Jul 28th, 2008, 10:11am
My question is how is the unity frequency or the Gm of the intergrator for that matter affect the filter behavior,frequences and responce.
You see i have a completed filter and i'm to redesign it in a different technology.I need to now what parameters i need check in the different parts of it to make sure I end up with the "same" responce.
What i understand is that from the passive prototype you can get the block diagram and from that the intergrators Gm.So  can I use the Gm or even better the unity frequencies to determind the filter behaviour?
buddypoor
Bremen, Germany
Reply #5 - Jul 28th, 2008, 10:44am
At first, I assume you speak about a LOWPASS response, right ?
(because it could be also highpass or bandpass).
For elliptic lowpass filters there are some different topologies available (that means different circuit diagrams) - even when they are derived from a passive prototype.
Each circuit alternative has it own design parametrrs - that means, without a circuit diagram nobody can give you any information.
Sorry, but thatīs the problem of filter design: A lot of alternative solutions with different and mostly conflicting proīs and conīs.
But I suppose you have got some design formulas, donīt you ?
Turin
Greece
Reply #6 - Jul 31st, 2008, 10:37am
Yes...I'm talking of a lowpass filter.This is the topology of the filter and the passive prototype
Reply #7 - Aug 3rd, 2008, 3:24pm
For the active amplifier version of the filter a general rule should be to keep the amplifiers parastic responses well outside the bandwidth of the active filters ole placement.
For example a 500MHz filter should be done using amplifier that have at least 800MHz BW at the worst PVT corner.
That way the response of the amplifier does not interere with the response of the filters defined poles (Bessel, Elliptic,  or Whatever pole constellation)
Generally, that tends to be the approach used, FWIW.
-Jerry
buddypoor
Bremen, Germany
Reply #8 - Aug 12th, 2008, 2:29am
Turin wrote on Jul 28th, 2008, 10:11am:
In order to answer this question it is necessary to derive the filters transfer function from the active circuitry.
Another way would be to evaluate the steps which have led from the passive to the active structure. In this case, you could use the internal differential equations (passive state space equations) to find the relations to the integrator stages of the active circuitry.
These are the only alternatives available to find the relations between flter parameters and the various integrator time constants.
vivkr
Reply #9 - Aug 12th, 2008, 7:06am
As already mentioned in various replies,
(a) you will need the active element to have a bandwidth a fair bit larger than the highest passband frequency.
(b) the filter topology chosen has a decisive influence on the exact amount.
You could do a sensitivity analysis. This can be done either by solving equations, or else, you just build a simple model of the filter, modelling the nonideal parameters of interest for your active elements (such as bandwidth), and simply do a little bit of parametric simulations to see the effect of the finite bandwidth on overall TF. You know the limits you must fulfil. You can get an idea of the required bandwidth.
However, atleast a very crude analysis on paper is good because then you know what influence you can expect from the finite bandwidth. Also, this allows you a good comparison between different topologies (of course, that can also be simulated, and much faster too).
Vivek
buddypoor
Bremen, Germany
Reply #10 - Aug 12th, 2008, 7:34am
Finally, after vivekīs reply, I`ve got the impression that there is a kind of misunderstanding between the questioner "turin" and the answering person(s) - perhaps only me ?
If turin speaks about the "integrator unity gain frequency" I assume he means what it sounds like: The frequency at which the integrator stage has a gain of unity - and the integrating time constant Ti is the reverse of this frequency.
But, of course, this is NOT the unity gain frequency of the active element alone, which - as it was stated - has to be much larger than the integrator unity gain frequency 1/Ti.
Hello turin, can you clarify this ? What do you mean with "unity gain frequency" ?
Turin
Greece
Reply #11 - Aug 15th, 2008, 6:12am
Thanks for the replies everyone.....
When i say unity gain frequency of the intergrator in Gm-c filters i mean:
ω=Gm/C....(with Gm and C refering to the transconductor and capasitor of the intergrator )
buddypoor
Bremen, Germany
Reply #12 - Aug 16th, 2008, 5:03am
Turin wrote on Aug 15th, 2008, 6:12am:
OK, that was already - and still is - my opinion. In this case, my reply No. 8 from august 12th is valid. That means, your question was NOT related to any parasitic amplifier influences and you are interested instead in the relation between the integrator time constant (itīs a better term that its reverse: integrator unity gain frequency) and the characteristic filter parameters. But, as I have mentioned, a general answer is not possible - it mainly depends on the chosen filter structure and the element dimensioning.
