Sep 29th, 2024, 2:17am
improve LDO PSRR (Read 6335 times)
trashbox
improve LDO PSRR
Aug 18th, 2008, 1:36am
Hi all guys,
I wanna design a high PSRR(-75dB) LDO (3.3v-->2.8v) with 3.3v device and the classic configuration is used: one stage nmos input pair error amplifier + a pmos (output stage).
However I found the PSRR at dc frequency is only -55dB. How to improve the PSRR performance? Thanks!
-- Trashbox
Berti
Re: improve LDO PSRR
Reply #1 - Aug 18th, 2008, 3:22am
I think that you basically need to improve the gain of your error amplifier.
HdrChopper
Reply #2 - Aug 18th, 2008, 8:02am
Hi Trashbox,
Berti is right. Basically the PSRR of your LDO is proportional to the loop gain which, for your topology is set by the error amplifier gain.
This is specially true at low frequencies, where parasitic components do not play a significant role in the PSRR performance. Certainly at very high frequencies the story will be different.
Tosei
Keep it simple
trashbox
Reply #3 - Aug 18th, 2008, 8:19am
Hi thechopper and Berti,
Thanks for your advice. I read a paper by Dr. Rincón-Mora from Gatech and he proposed a PSRR model for LDO which has the same conclusion.
spanandiyer1979
Reply #4 - Nov 3rd, 2008, 7:59am
Hi Guys
Can you please take the time for answering my following queries regarding the LDO design:
1) I wanted a LDO design methodology for a low drop out regulator with an input voltage range of 2.8+/-10% , output voltage of 1.8V and a load current of 10mA to 50mA.i mean from the system specs , down to the amplifier specs etc.
2) How practical is it to design an LDO without an output capacitor.
thanks
anand
