Sep 29th, 2024, 2:18am
would 0.13u mosfet will be damaged  under 2V voltage? (Read 3860 times)
xwj623
Sep 09th, 2008, 1:17am
Can i put a 0.13 nmos under 2v voltage?
AnalogDE
Re: would 0.13u mosfet will be damaged  under 2V voltage?
Reply #1 - Sep 9th, 2008, 1:18pm
That would depend on your design rules... check with your process guys.
Reply #2 - Sep 11th, 2008, 11:34am
find the maximum tolerable Vgs and Vds (and others) for the foundry process, and if you respect those limits all the time (on, off, startup, shutdown, **all** conditions) you should be able to do it.
jordan76
Truth always lies in
the details.
China
Reply #3 - Nov 19th, 2008, 7:20pm
Hi xwj623,
This mainly depends on the break-down voltage of the MOS devices in the process you intend to use. As a rule of thumb, 0.13um MOSFET break-down voltage will be about 2.08V(gate oxide ~2.6nm->2.6x0.8=2.08V). Therefore I would  strongly suggest you NOT to do so if taking voltage variation etc into account.
Of course you will get more detailed information from your foundry which I believe will give you same advice.
Hope it helps a little.  ;)
regards,
jordan76
regards,
Jordan76
View Profile jordan76   IP Logged
Tareeq
Reply #4 - Nov 20th, 2008, 9:05am
To the contrary to what says Jordan, a voltage lower than authorized is  usually not an issue from a device reliability point of view.
Whatever comment put here, it is your design manual that gives you the final point.
Regards.
Tareeq
jordan76
the details.
China
Reply #5 - Nov 28th, 2008, 12:19am
Hi Tareeq,
First of all, I agree that it is your design manual that gives you the final point. On the other hand I personally still believe that the consideration of device reliability is the primary reason behind voltage range recommendations in the design manuals.
Still I am open to different ideas/opinions if justified sufficiently.
regards,
Jordan76
