Sep 29th, 2024, 4:19am
opamp (Read 3277 times)
raja.cedt
opamp
Sep 10th, 2008, 12:53am
hi,
   i have designed a  two stage op amp with 1v supply in 65nm tech.
   input common mode voltage=0.4 to 0.7
   output bias point =0.5(swings from .2 to .9 )
now i connected in  non inverting configuration  with gain 3 then it is saturating because of output swing limitation(actually op amp trying to go 1.2  because non inverting input i gave .4 as bias )  means op amp is trying to amplify both signal as well as bias. Is there any method to subtract bias voltage in the feed back  so that we can get wide range of gains
thanks
aidnaal
Re: opamp
Reply #1 - Sep 10th, 2008, 5:07am
Could you please send the schematic of the circuit (non inverting configuration)?
HdrChopper
Re: opamp
Reply #2 - Sep 11th, 2008, 7:26pm
It sounds to me you are connecting the feedback resistors to DC GND rather than an AC ground whose DC bias point should be the same as the input common mode.
In this way you will not amplify the bias point and will take advantage of the output dynamic range.
This is the only way a non-inverting amplifier can work without amplifying the DC operating point. Otherwise you will have to use an inverting configuration
Tosei
Keep it simple
raja.cedt
Re: opamp
Reply #3 - Sep 12th, 2008, 3:42am
hi Tosei,
          thanks for your answer.but how to give that bias.if you do some bias generation circuitry then it will directlly come with feedback network and all most all bias circuits are active networks.So the greatness in feedback  networks is output is accurately  defined by feedback passive elements now output is not accurately defined.
        How inverting amp will help in this regard.There also we have to give bias for non inverting pin rather than dc ground.
Thank you.
HdrChopper
Re: opamp
Reply #4 - Sep 18th, 2008, 7:42pm
Hi
In order to make it work without amplifying the bias circuit you have to separate the bias from the signal to be amplified. Otherwise you will amplify the DC bias input voltage. See the drawing for reference
Tosei
Keep it simple
