Sep 29th, 2024, 4:21am
Fourier Transform of Integration (Read 2629 times)
qiushidaren
I am a lovely
MOSFET!
Chengdu
Sep 14th, 2008, 1:12am
I have a question recently which I couldn’t find an answer to, when I was an undergraduate in univercity, that is where dose the second term πX(0)δ(ω) come from in the formulation for Fourier Transform of Integration which is showed below, I can’t find any details from Oppenhim’s classical book Signals and Systems, can anybody help me about this confused question?
-Terry
Re: Fourier Transform of Integration
Reply #1 - Sep 14th, 2008, 2:32am
qiushidaren wrote on Sep 14th, 2008, 1:12am:
πX(0)δ(ω) come from in the formulation for Fourier Transform of Integration.
As far as my memory is correct, such issue is descripted also in a famous classical text book you refer.
Or see text books written by "A.Papoulis".
From direct thought, if X(0) is not zero, it is very reasonable there is an impulse spectrum around ω=0 for integral of x(t).
Here X(ω) is fourier transform of x(t).
[Mathematical Hint]
Fourier transform of step function u(t) is πδ(ω)+1/jω.
Here you have to learn a nature of delta function δ(ω).
If ω*F1(ω)=ω*F2(ω), it must be F1(ω)=F2(ω)+k*δ(ω), here k is any constant.
« Last Edit: Sep 14th, 2008, 5:52pm by Forum Administrator »
HdrChopper
Reply #2 - Sep 18th, 2008, 7:28pm
Hi
I could find it finally....
The Fourier transform of the  ∫x(t) dt between -∞ and t is 1/ω*F(ω) provided that ∫x(t) dt between -∞ and +∞ is zero (such integral is the "DC component of x(t) )
If that is not the case, then ∫x(t) dt between -∞ and t can be expressed as ∫x(t)u(k-t)dt between -∞ and +∞, which is the convolution integral. Applying the Fourier transform to the convolution you get the product of the two functions spectra and therefore the composite fourier transform will be:
1/jω*F(ω)+ π*δ(ω)*F(ω) and δ(ω)*F(ω) = δ(ω)*F(0)
Hope this helps
Tosei
Keep it simple
qiushidaren
I am a lovely
MOSFET!
Chengdu
Reply #3 - Oct 16th, 2008, 6:48pm
Thank you, I understand it now. Wink
-Terry
