Apr 19th, 2024, 9:12am
Adaptive Equalizer (Read 972 times)
storm
Singapore
Adaptive Equalizer
Sep 18th, 2008, 12:22am
hello all, i want to know whether you guys have any experience on designing equalizer or not. For say a 5Gbps transceiver, what kind of architecture and error generation as well as the searching algorithm would you recommend to use? I tried to search this forum but didnt find any discussion on this topic. Will you normally use FIR filter and BPF method? how do you search those FIR filter coefficients?
Thank you.
email_gz
gaoz.mail@gmail.com
Re: Adaptive Equalizer
Reply #1 - Sep 24th, 2008, 8:09pm
Hi storm:
   for 5Gb/s PCB, Tx-Fir + Rx-CTLE/DFE is good  choice.
   using zero-forcing find MMSE FIR parameter then do LMS  Adaptation.
   JSSC 2008-9 take another way to do adaptive equalizer
View Profile email_gz email_gz   IP Logged
kanan
Reply #2 - Jun 7th, 2009, 9:02pm
I have looked at a number of papers on serial link equalization and they all seem to be looking at the signal power at various frequencies and flattening the response. Any idea why phase response is not considered?
Or am I missing something?
neoflash
Mixed-Signal
Designer
Reply #3 - Oct 5th, 2009, 12:29pm
email_gz wrote on Sep 24th, 2008, 8:09pm:
Hi storm:
I think initial MSE estimation or zero-force algo is difficult. If there is no ADC in the Rx, it is not likely to do any calculation for MSE and ZF algo.
love_analog
Reply #4 - Apr 7th, 2010, 2:08pm
Typically for 5G, people have not been using DFE. Only nowdays has DFE become more popular.
If that is an issue, at 5G you could be able to get away with just Tx and Rx Linear equalizers. This depends upon making sure your channels aren't heavily attenuated or reflective.
loveanalog.blogspot.com
The Power of Analog
