Apr 16th, 2024, 11:06am
Capacitor simulation (Read 10809 times)
gorkhim
San Jose
Sep 28th, 2008, 5:44pm
I am trying to estimate the equivalent series resistance, quality factor and capacitance for a MIM capacitor in 90nm process technology using S-parameter analysis in Cadence IC5141.
After running the analysis, I am using the Y-parameters to plot the G, C & Q using the following equations:
1. G =  real(Y11 - ((Y12*Y21)/Y22))
2. C = -imag(Y11 - ((Y12*Y21)/Y22))/(2*pi*f)
3. Q= -imag(Y11 - ((Y12*Y21)/Y22))/real(Y11 - ((Y12*Y21)/Y22))
The plot for these equations is attached. These plots are not making any sense. Does anyone have any clue about what am I doing wrong?
Also when I use a similar test-bench for an inductor, these equations works properly
Thanks.
Berti
Re: Capacitor simulation
Reply #1 - Sep 28th, 2008, 11:58pm
Unfortunately, your graphic is hardly readable.
However, are you sure that the MIM capacitor model includes a series resistance.
In the DK I am using, the no series resistance is modeled for the MIM capacitor, unless
you add it from parasitic extraction.
gorkhim
San Jose
Reply #2 - Sep 30th, 2008, 1:59pm
Thank you for your quick response. Yes there was wrong model file.
Reply #3 - Dec 12th, 2008, 1:29am
Hi gorkhim,
Why do you measure the Q/G/C with 2 ports. It is one port for a varactor actually. The formula is simpler if simulating with one port.
1. G = real(Y11)
2. C = imag(Y11)/(2*pi*f)
3. Q= imag(Y11))/real(Y11)
Yawei
