Sep 29th, 2024, 4:19am
how to measure offset (Read 4508 times)
analoghua
Oct 15th, 2008, 4:11pm
Hi, it is my understanding that the OpAmp or comparator offset is caused by the mismatch of the transistors (mainly the input differential pair?). so how to exactly measure the input-referred offset voltage in Cadence virtuoso schematic environment? Do I have to add mismatch in the transistor models? Thanks.
Berti
Re: how to measure offset
Reply #1 - Oct 15th, 2008, 10:47pm
Either do the calculation by hand (which is not so bad as you will gain insight) or run a monte-carlo simulation as described in
http://www.designers-guide.org/Analysis/comparator.pdf
Or even better, do both hand analysis and simulation.
Cheers
HdrChopper
Reply #2 - Oct 16th, 2008, 3:47pm
A "dcmatch" analysis would also be a very good first approach. In the case of the comparator its input should be balanced when running the analysis, since it is the condition at which it will change its state and therefore when offset is meaningful.
Tosei
Keep it simple
