Sep 29th, 2024, 2:14am
FIB operation on a 1GHz signal (Read 1957 times)
neoflash
Mixed-Signal
Designer
Oct 17th, 2008, 8:38am
  Recently I have been debugging a design on 0.13um process.
  One bug requires cutting and reconnecting (12um) a signal running at 1-2 GHz. This signal is on a timing path.
  I would like to know more about the potential impact of FIB operation on the performance of propagation delay?
Neo
rf-design
Reiner Franke
Re: FIB operation on a 1GHz signal
Reply #1 - Oct 17th, 2008, 10:55am
The FIB have a specific sheet resistance which is in between metal and poly. So the RC-delay impact increases.
Paul
Switzerland
Reply #2 - Nov 11th, 2008, 1:10pm
Hi Neo,
Conducting material is usually platinum or tungsten, the latter being 2x less resistive, though still 3x more than Cu. Notice the deposition for longer stripes is done in several steps, which again increases resistivity.
I am a designer, not a FIB guy, but I would guess that at best you might get some samples operating at the desired speed, but the FIB yield at these frequencies might not be tremendous. At least, talk to your FIB guys before proceeding, they should know better what you can expect based on the actual case (how deep do they have to mill before getting to the desired wire, how large is the wire to contact, etc...).
This might not be critical to you, but FIB usually also comes with some leakage in the milling region.
Paul
