Sep 29th, 2024, 2:16am
abt saturation current in BJT (Read 3810 times)
VINAY RAO
Oct 19th, 2008, 11:06pm
In mos ,saturation region means the maximum current that cant be increased more i.e means current is saturated.But in BJT it is reverse.WHY in BJT even though current can be increased ,region we get when both the junction are forward biased is called saturation region??
I hope for positive reply..Pl help me to understand..
raja.cedt
Re: abt saturation current in BJT
Reply #1 - Oct 20th, 2008, 12:00am
hi,
in bjt saturation means not regarding current,instead it means toal charge in the base has reached saturation.i hope u got my point
VINAY RAO
Reply #2 - Oct 20th, 2008, 11:28pm
Sry,iam not clear abt it.But chrge in base will be increased in base  in saturation region, will it nt increase further if we increase forward bias voltage of CB junction ( means when we r driving device more into saturation region)?????
raja.cedt
Reply #3 - Oct 21st, 2008, 1:33am
hi,
i mean when BJT is in active region ic=Β*ib,wheras when its in saturation region ic<Β*ib.hence even though u increase base drive ib will increse,but inside recombinations will keep ic to be at the same value.means net charge is fixed.where as in active regoin charge keeps increasing with base drive and hence collector current(note that here charge is increasing ) .i hope u got my point
raja.cedt
Reply #4 - Oct 22nd, 2008, 2:01am
hi, i forgot to mention about the book name "modular series on BJT".they have given very clearly this point.
VINAY RAO
Reply #5 - Oct 23rd, 2008, 10:40pm
Thanks a lot,,do u hv soft copy of that book??
raja.cedt
Reply #6 - Oct 23rd, 2008, 11:25pm
no man,that to its a costly book.so u better buy the follwoing books.it is indian addition
Semiconductor Device Fundamentals by R. F. Pierret
(Addison Wesley, 1996)
Thank you,
