Sep 29th, 2024, 2:15am
Pages: 1 2
constant gm bias goes unstable after modification (Read 18235 times)
HdrChopper
Re: constant gm bias goes unstable after modification
Reply #15 - Nov 06th, 2008, 2:46pm
I agree with you buddypoor.
In this particular case however, I think the overall stability could be evaluated by breaking the loop at the node that both loops share. This is a special case when a multi-loop system could be analyzed as a single loop one (the usual way)
Tosei
Keep it simple
Tlaloc
Dallas, TX
Reply #16 - Nov 6th, 2008, 2:57pm
buddypoor wrote on Nov 6th, 2008, 2:08pm:
I like to remind you on the Nyquist stability criterion in its most general form. This criterion allows us to prove the stability of a closed loop system also in case that the open loop is unstable (i. e. it has poles with a positive real part).  There are a lot of examples that closing one specific loop can stabilize another loop which is unstable.
You are quite right.  In fact I have designed such a system before, but it had slipped out of my mind.  In that circuit, I had two feedback paths, one positive and one negative.  I did run stability on both loops since I needed to verify that the negative path always had greater loop gain.  Otherwise the positive feedback would become dominant, and I would have an oscillator.
I still think that it would be informative to run the three stability analyzes, though.  Even though all are negative feedback, if one is flirting with instability, you should see it.
buddypoor
Bremen, Germany
Reply #17 - Nov 6th, 2008, 11:00pm
HdrChopper wrote on Nov 6th, 2008, 2:46pm:
Tosei
Yes, Tosei, thatīs correct.
A simple example is an opamp with positive and negative feedback (of course, the neg. feedback must dominate). In that special case the positive loop simply reduces the negative loop gain and, therefore, both loops must be broken at the same time.
Frank Wiedmann
Munich, Germany
Reply #18 - Nov 7th, 2008, 1:02am
I agree with both of you. If all loops can be broken at a single path, one should examine the circuit like this. The general criterion for stability of multi-loop circuits is rather complex, see http://www.designers-guide.org/Forum/YaBB.pl?num=1217822985.
Pages: 1 2
