Sep 29th, 2024, 2:15am
Local Oscillator Buffer Design (Read 2348 times)
Hendy06
USA
Nov 11th, 2008, 9:36pm
I need to design an LO buffer that drives a double balanced mixer, but i'm not sure what the structure of the oscillator will look like.  I understand that the LO will be fixed at a specific frequency, so is it ok to use a VCO type structure to create the oscillator?  Or can i just use a pulse generator to produce the LO signal?  Would anyone be able to point me to references that might inspire me?
fonseca.ha
UK
Re: Local Oscillator Buffer Design
Reply #1 - Nov 16th, 2008, 11:27am
Hi. Can you give some more details about the problem. Are you also designing the oscillator or just the buffer? Do you  get from the oscillator a differential signal? Will you have to drive rail to rail into the mixer?
Hendy06
USA
Reply #2 - Nov 22nd, 2008, 1:46pm
Only the buffer needs to be designed.  The LO buffer needs to drive the mixer with a differential signal and the assumption will be that the input to the buffer will be driven by differential signals from the VCO.  The LO signal will be 300mVpp (1.8V supply).
