Sep 29th, 2024, 2:18am
regulator design steps? universal testbench? (Read 1552 times)
Benjamin
Nov 11th, 2008, 9:36pm
Can someone recommend a step by step guide covering basics like sizing the differential pairs, choosing tail current, second stage to first stage sizing ratios, etc etc?
I have used the universal testbench with two diffamps in series in order to measure gain, CMRR, but could use a step by step guide to go along with the unviersal testbench.
I am familiar with how to verify 2 stage diffamps and folded cascode regulators.
But need to learn more about ground up design steps.
Any suggestions are appreciated?
Thanks in advance.
Re: regulator design steps? universal testbench?
Reply #1 - Nov 11th, 2008, 10:03pm
I don't know what the universal test bench is, but you can measure a lot of transfer functions all at once using an XF analysis. Combine it with ideal baluns to handle differential circuits.
