vanjer wrote on Nov 29th, 2008, 3:33am:Is the wire loop can be measured by VNA as well? or, in other word, is the simple wire loop (not DUT) has certain bandwidth which can be measured by the VNA?
Maybe you can evaluate it since antenna is far from matching(or resonance).
vanjer wrote on Nov 29th, 2008, 3:33am:I attached the picture of the wire loop that given to me. Why the 50 must be present there?
Maybe this antenna is used as TX which is connected to signal generator.
Then DUT antenna is connected to spectrum analyzer as RX.
Also this 50Ohm makes Q of antenna lower regardless of this antenna as TX or RX.
Characteristics of antenna is reciprocal regarding TX and RX.
Since small loop wire antenna is far from resonance, it's frequency characteristics is broad enough for evaluating DUT antenna.
This means a gain of small loop wire antenna is very small.
So you can evaluate DUT antenna by small loop wire antenna.
But if you evaluate only resonance frequency of DUT antenna, you should use network analyzer without using small loop wire antenna.
