Your problem is not "Behavioral Models" at all. It is no more than simple and easy common usage of simulator.
bandpass wrote on Feb 22nd, 2009, 5:32am:The problems: the VCO works well under 10uS, but the output is wrong when tran simulation larger than 10uS.
This is due to very very simple and easy reason.
You are trying to plot too many points(200u/1p=200Mpts).
In your environment, data points upto 10Mpts(=10u/1p) are permissible.
And you don't specify "delmax" in your netlist.
When you do transient analysis, you have to consider reasonable values setting about tstop, tstep, delmax, trise and tfall.
This is very common sense which is true for any vendor's simulator.
Modified vco.sp
Quote:** Generated for: hspiceD
** Generated on: Feb 17 19:55:41 2009
** Design library name: beh_kundert
** Design cell name: PLL_usb_sim
** Design view name: schematic
.hdl "vco.va"
.TEMP 25.0
** Library name: beh_kundert
** Cell name: PLL_usb_sim
** View name: schematic
xi1 out in vco vmin=0 vmax=1 fmin=1.5e9 fmax=3e9 vl=0 vh=1.2 tt=100e-15 ttol=100e-15
*xi1 out in vco3_kundert *vmin=0 vmax=1 fmin=1.5e9 fmax=3e9 vl=0 vh=1.2 tt=100e-15 ttol=100e-15
v1 in 0 DC=1 *AC 1 PULSE 0 1.2 0 1e-9 1e-9 9e-9 20e-9
*i9 clk_fb div25_out divider1 vh=1.2 vl=0 vth=600e-3 ratio=2 dir=1 tt=1e-12 td=1e-12
.OPTION
*+ ARTIST=2
+ INGOLD=2
+ MEASOUT=1
+ PARHIER=LOCAL
*+ PSF=2
+ post = 1
+ probe
+ delmax = 0.1n $ maximum internal time step
*.OP
*.TRAN 1e-12 200e-6 START=0.0
.TRAN 10n 200u START=0.0
* 200u/1p=200Mpts <--- Your Setting
* 200u/10n=20kpts <--- My Setting
.probe tran V(in) V(out)
.END
