Mar 28th, 2024, 5:16am
PLL phase diognosis? (Read 9986 times)
liletian
MD
May 04th, 2009, 9:02am
 Hi guys
 The attached pic is a ring oscillator PLL, the spectrum has some lines which I assume which comes from ring oscillator? Any suggestion on origination and how to purified it? Any suggestion will be appreciated!
Re: PLL phase diognosis?
Reply #1 - May 4th, 2009, 9:09am
Why do you set RBW=VBW=8MHz ? It is very wide.
liletian wrote on May 4th, 2009, 9:02am:
I can't observe remarkable spurious spectrum lines.
Floor spectrums are very dirty.
Maybe this is due to your measurement conditions, such as voltage power supply.
Or this might be improper loop filter design.
liletian
MD
Reply #2 - May 4th, 2009, 9:23am
pancho_hideboo wrote on May 4th, 2009, 9:09am:
I can't observe remarkable spectrum lines.
Or this might be inproper loop filter design.
 the loop filter is a simple RC filter, is that the problem? I did not use active filter in here because I did not see much advantages.
Reply #3 - May 4th, 2009, 9:29am
liletian wrote on May 4th, 2009, 9:23am:
Do you determine bandwidth of loop filter by enoughly considering followings.
  - Reference frequency(Comparison Frequency)
  - Corner frequency of VCO phase noise
Again see surely http://www.designers-guide.org/Forum/YaBB.pl?num=1241145270/4#4
Anyway floors of your spectrum are very high and dirty regardlerss of RBW=VBW=8MHz which are very wide.
You should consult someone who has much experience of actual RF measurements about your measurement setups and usages of instruments.
« Last Edit: May 4th, 2009, 10:47am by pancho_hideboo »
liletian
MD
Reply #4 - May 5th, 2009, 7:59pm
pancho_hideboo wrote on May 4th, 2009, 9:29am:
 I use signal generator to generator signal at 2Ghz
 do you mean 1/f^3 noise? How could loop filter will affect affect Corner frequency and Reference frequency?
 Thank you
Berti
Reply #5 - May 6th, 2009, 3:33am
I am just wondering: What's the loop filter bandwidth?
liletian
MD
Reply #6 - May 6th, 2009, 7:45am
Berti wrote on May 6th, 2009, 3:33am:
500MHz
loop filter bandwidth is approximately equal to pll lock range, right?
Reply #7 - May 6th, 2009, 8:45am
Expression of "the loop filter bandwidth" is not proper.
Correctly it should be loop bandwidth of PLL.
« Last Edit: May 6th, 2009, 9:50am by pancho_hideboo »
Reply #8 - May 6th, 2009, 8:45am
I think default RBW is 3MHz for your Spectrum Span.
You dared change RBW from 3MHz to 8MHz.
liletian wrote on May 5th, 2009, 7:59pm:
Can your phase comparator work in 2GHz directly ?
Do you understand "Comparison Frequency" ?
See text books on basic of PLL.
See figure-20 of http://www.designers-guide.org/Analysis/PLLnoise+jitter.pdf
Berti
Reply #9 - May 7th, 2009, 12:00am
Hi again,
I am confused. From your spectrum, the 'loop bandwidth of the PLL' (thanks for the proper terminology!  ;) ) doesn't look like 500MHz but more like 50MHz. Furthermore the comparison frequency of 2GHz seems to be pretty high and somehow doesn't sound correct for a loop bandwidth of 500MHz.
I think it is difficult to help you with the measurements when there are even confusions on the PLL itself.
Cheers
liletian
MD
Reply #10 - May 9th, 2009, 7:12pm
Berti wrote on May 7th, 2009, 12:00am:
Hi again,
Cheers
 Hi Berti
 when I mentioned it, it means the RC filter's pole location. 1/(1+w/w0). I guess you guys definition is "The
loop bandwidth is defined as the
integrated magnitude of the PLL
frequency transfer function over
the entire frequency spectrum." please let me know. Also, how can you see my PLL's loop bandwidth is less than 500MHz.
 Thank you
rfmems
Reply #11 - May 10th, 2009, 3:06am
liletian wrote on May 9th, 2009, 7:12pm:
First question, you are really using a RC filter (one R and one C)? If that is true, what kind of phase comparison circuit are you using?
I guess you guys definition is "The loop bandwidth is defined as the
integrated magnitude of the PLL frequency transfer function over
Yes, I think we are all talking about pll bandwidth, not the loop filter bandwidth.
I did not check you spectrum, but first of all, if you vco is free running, no information can be seen from your meansurment. And loop bandwidth of 500MHz is very big, and if that is true, what is your comparison frequency?  If you can tell your loop filter R and C values, PFD/PD structure, kvco, maybe I can help you to figure out what might be wrong.
cheers
rfmems
