aNaloG_y wrote on Jun 22nd, 2009, 8:40am:In AC analyis if you write gain expression in ADE e.g 20*db20("VT(/<netname>"),this expression will be plotted at the end of AC analysis.
Not correct. This has to be VF(). And "20*" is redundant.
aNaloG_y wrote on Jun 22nd, 2009, 8:40am:But in PAC,once run is over I need to go and select the PAC results and then plot the gain expression using calculator.
No, you don't seem to be familiar with Cadence ADE.
Choose "ADE>Results>Direct Plot" for both ac and pac with "Add Outputs=On".
Or use result browser for both ac and pac. Then invoke calculator and do "get expression".
In anyway, you can get following expressions in output field.
db20( v("/<netname>" ?result "ac-ac") )
db20( v("/<netname>" ?result "pac-pac") )
