Apr 24th, 2024, 12:57pm
DDR3 circuit design references (Read 9617 times)
AnalogDE
Jul 28th, 2009, 1:37am
I will be working soon on DDR3 I/O circuits...Could you suggest some good starting references for DDR3 and/or high-speed I/O design in general?
Thanks!
neoflash
Mixed-Signal
Designer
Re: DDR3 circuit design references
Reply #1 - Oct 5th, 2009, 12:58pm
DDR3 is mostly custom design and doesn't have much publications on it.
Be prepared to search for DLL, phase interpolator.
AnalogDE
Reply #2 - Nov 5th, 2009, 10:20am
I'm working on the ZQ calibration circuit.  If I'm reading the spec correctly, the circuit needs to be capable of sensing a 0.5% change in output driver impedance.  Translated into a deltaV I calculate this to be 1.8mV at the input of the comparator.  This means I need to design the comparator to have an offset voltage =1.8mV (say over 3sigma) or does it need to be less, say half that?
If it's half that, then I need to burn 4x the power and spend 4x more area on the comparator.  I'm thinking it's OK to design it to be =1.8mV over 3sigma...  is my thinking wrong here?
SacY
Be A Change You want
to see in the World
Hubli
Reply #3 - Nov 17th, 2009, 5:16am
Jiesteve,
Before I comment on anything can you please let me know how you calculated 1.8mv. Because as per DDR3 spec the deltaV = (vdd/2) * 0.5%
which will come around 3.75 mV as vdd will be 1.5V as per standard.
Thanks and Regards
Sachin
AnalogDE
Reply #4 - Nov 24th, 2009, 7:28pm
Hi SacY,
The DDR3 spec calls for the ZQ circuit to be sensitive to 0.5% of _RZQ=240 ohms_
This is how I calculated deltaV:
Taking VDD=1.5v: (find voltage change with 0.5% change in driver resistance:
V = ( 240*(1.005) / 240 + 240*(1.005) ) * VDD
Then take the difference from midpoint 1.5/2 = 750mV.
pavanspai
Reply #5 - Jan 10th, 2010, 10:44pm
Hi ,
I am working on ZQ calibration of DDR3 , according to electrical characteristics of ODT/Driver impedance can very +/- 10% .
But the short calibration is capable of correcting the impedance error up to 0.5% . And calibration interval calculated with this as reference , will always run whenever impedance falls out of the impedance error limit.
That means impedance always will be calibrated to +/- 0.5% .
In such case why the electrical specs allows +/-10% variation ?
