vivkr
Hi Rampat,
It is always risky to predict the future. However, the following things are likely to keep analog designers busy:
1. Ever faster operating speed requirements. 2. Ever tighter power consumption constraints. 3. Ever higher levels of integration, eliminating external components. 4. Increasing amount of on-chip sensors and need to drive these => more data converters, on-chip dc-dc converters/power management.
If you wish to prepare for the future, then you would do well to sharpen your understanding of the fundamental concepts. That would allow you to work in about any field, provided that you are motivated enough.
Vivek
