Sep 27th, 2024, 12:14am
buffer in LDO (Read 3884 times)
Dipankar
buffer in LDO
Nov 19th, 2009, 9:10am
Want to design a buffer interposed between error amplifier and PMOS pass device. (Iload being 50 mA pass device is huge) . But vin = 1.2 V. So can't use a simple source follower because of voltage level shift. Can some one hint at some other approach ?
With Thanks and Regards,
Dipankar.
raja.cedt
Re: buffer in LDO
Reply #1 - Nov 20th, 2009, 6:08am
hi,
  whats the problem with big device man,there are many low jitter plls with ring oscillators are drawing 30 to 40ma, you can proceed, if you want to put a buffer again you have to compensate loop. This will give very bad PSRR.
Rajasekhar.
Mayank
Re: buffer in LDO
Reply #2 - Nov 20th, 2009, 6:45am
Thanx raja,
               That's exactly what i needed to know....that there exist low jitter plls which take powers up to 30 - 40 mA with ring osci's on 1.2V supply....& that my design is not so bad after all.....But about how low jitter & what osc freq.+comparison freq. pair are you referring to at this much power burnout ??
--mayank.
raja.cedt
Re: buffer in LDO
Reply #3 - Nov 20th, 2009, 7:41am
hi,
  it's around 6.2G, but here actually ring oscillator driving many phase mixer.
rajasekhar.
Dipankar
Re: buffer in LDO
Reply #4 - Nov 20th, 2009, 6:42pm
Dear Sirs,
                Please don't diverge from the topic under this thread.
The motivation behind the buffer in the LDO (after the 1st gain stage)  is not enhancing driving capability but impedaance transformation so that the high output impedance of the 1st stage amplifier  does not see the high capacitance of the pass device.
Dipankar.
Mayank
Re: buffer in LDO
Reply #5 - Nov 20th, 2009, 8:04pm
Correct me if i am wrong dipankar,
                   but isn't the error amplifying Loop supposed to have as low BW as possible....So Increased cap should reduce BW & improve PM of the loop....
--mayank
raja.cedt
Re: buffer in LDO
Reply #6 - Nov 21st, 2009, 8:58am
hi Dipankar,
                 the motivation behind buffer is mainly for driving capability,not impedance..just check impedance, i feel its same in both cases.
@mayank: how can say error amp bw is low? it depends on the psrr profile you want.
Rajasekhar.
Mayank
Re: buffer in LDO
Reply #7 - Nov 26th, 2009, 7:45am
         Sorry for the delay....was busy in past few days...
   @ raja : I believe that more the error amplifier BW, more the noise introduced at the Vbias node (gates) of the PMOS transistors...
 Lemme explain it this way....Suppose opamp has some finite UGB Fo......It will process all noise elements in supply below Fo as small signal input and vary the output accordingly.....But all high frequency noise above Fo will not change the output of the opamp..Which is what we desire....
   This way if Error Amplifying Loop BW is very Low, we will get even better supply noise rejection
Could you explain it further ??
--mayank
raja.cedt
Re: buffer in LDO
Reply #8 - Nov 26th, 2009, 9:56am
hi mayank,
               what i want to say is opamp BW is mainly decided by AC psrr.......
Rajasekhar.
