Mayank
Hi, What exactly do you mean by Volt-Amperic characterstics of a MOS ? 1. Are you referring to input-output transfer characterstics (id vs. vgs) ? OR 2. Are you referring to output transfer characterstics (id vs. vds for diff vgs ) ??
Anyways for both, you have two variables vds & vgs....In your schematic, place two voltage sources so as to vary these two variables....say, you keep your source voltage fixed...place one b/w source & drain & other b/w Source & gate.....Do a nested sweep....Obtain all characterstics that you want....
hope it helps, mayank.
