Sep 27th, 2024, 10:21am
PMOSFET Volt Ameperic characteristics (Read 1670 times)
Shlapenka
Nov 20th, 2009, 6:17am
greetings everyone,
How can i get PMOSFET Volt Ameperic characteristics? I know i need 2 DC sources and my PMOSFET, but how do i arrange a scheme? Witch node goes where (drain, gate source)?
Tyvm for help!
Mayank
Re: PMOSFET Volt Ameperic characteristics
Reply #1 - Nov 20th, 2009, 6:56am
     What exactly do you mean by Volt-Amperic characterstics of a MOS ?
      1.  Are you referring to input-output transfer characterstics (id vs. vgs) ?
OR 2.  Are you referring to output transfer characterstics (id vs. vds for diff vgs )  ??
Anyways for both, you have two variables vds & vgs....In your schematic, place two voltage sources so as to vary these two variables....say, you keep your source voltage fixed...place one b/w source & drain & other b/w Source & gate.....Do a nested sweep....Obtain all characterstics that you want....
hope it helps,
mayank.
Shlapenka
Reply #2 - Nov 20th, 2009, 7:12am
helped perfetly, thank you Smiley
