Sep 27th, 2024, 6:21am
MOSFET resistor (Read 1989 times)
Shlapenka
MOSFET resistor
Nov 20th, 2009, 7:25am
Greetings,
what makes a MOSFET transistor act as a resistor? Is it W>L (W lenght more than L lenght)?
raja.cedt
Re: MOSFET resistor
Reply #1 - Nov 20th, 2009, 7:37am
if you some what resistance (with some non linearity) use transistor in triode region, and if you want good linearity use symmetric load (simply search in Google..you will get john mennatis pap in self bias plls)
Rajasekhar.
buddypoor
Bremen, Germany
Re: MOSFET resistor
Reply #2 - Nov 20th, 2009, 8:22am
Shlapenka wrote on Nov 20th, 2009, 7:25am:
Greetings,
Each FET, indeed, is a resistor!
It consists of a channel which can lead an electrical current if you apply a voltage across the channel - and that,by definition, is a resistance.
The only (but important) difference to an ohmic resistor is the fact, that there is a quasi-linear relationship between voltage and current only within a limited voltage range (some tenth of volts around zero).
More than that, the value of this resistance can be controlled with the gate voltage.
Shlapenka
Re: MOSFET resistor
Reply #3 - Nov 21st, 2009, 2:16am
thank you all for info Smiley
