Sep 26th, 2024, 10:21pm
Oscillators - Phase Noise Degradation (Read 2023 times)
Mayank
Nov 26th, 2009, 6:29am
    I have designed a CML Voltage-Controlled Oscillator in 65nm process.
        Without the bias ckt (using ideal voltage source), the Oscillator shows -55 dBc @ 10kHz.....
          How much degradation can i expect in this Phase Noise when i add a bias ckt with Replica Biasing scheme ??
thanx
mayank.
Re: Oscillators - Phase Noise Degradation
Reply #1 - Nov 26th, 2009, 4:53pm
tough to say  - sounds like the best thing you can do is get it down to transistors and run Spectre PSS and Pnoise analysis.
jerry
Mayank
Reply #2 - Nov 27th, 2009, 1:00am
Hi Jerry,
            Already carried out a PSS/PNOISE simulation on one of my designs...Got +ve Phase Noise ie > 0 dBc values
......Had a long Discussion with one of the senior members, Pancho_hideboo in the rf_simulators forum starting from http://www.designers-guide.org/Forum/YaBB.pl?num=1050465395/0#8
...Seems like none of the simulators are able to give correct results for Phase noise below the line-width of the oscillator. Any fix for this ??
--mayank.
Reply #3 - Nov 27th, 2009, 2:09am
Mayank wrote on Nov 27th, 2009, 1:00am:
I think an integration without including suspicious frequency region is still enough useful for evaluation of jitter or phase noise.
« Last Edit: Nov 27th, 2009, 10:53am by pancho_hideboo »
