Sep 27th, 2024, 3:19pm
Discrete capacitors for Analog Front End. (Read 3638 times)
ic_engr
Dec 16th, 2009, 8:31am
Hello All,
I am wondering if anyone know if SMD capacitors are now available in smaller than 0201 sizes. My maximum capacitor is 100nF.  Currently we get capacitors from pF to 220nF in 0201. I am looking for sizes smaller than 0201 for 100nF capacitance.
ic_engr
Re: Discrete capacitors for Analog Front End.
Reply #1 - Dec 16th, 2009, 8:38am
ic_engr wrote on Dec 16th, 2009, 8:31am:
You mean "0603" size ?
Currently "0402(01005)" sizes are available as mass products.
See http://www.yuden.co.jp/us/product/goods_top/goods_top1.html
« Last Edit: Dec 16th, 2009, 10:09am by pancho_hideboo »
ic_engr
Reply #2 - Dec 16th, 2009, 8:54am
No. I meant 0201. Currently you can get in 0201 capacitors upto 100nF.
I am looking for smaller footprint for 100nF and lower capacitors.
ic_engr
Reply #3 - Dec 16th, 2009, 9:03am
ic_engr wrote on Dec 16th, 2009, 8:54am:
What do you mean ?
You mean "Low-Profile" ?
You mean 0.2mm x 0.1mm ?
I don't know such size.
Again see http://www.yuden.co.jp/us/product/goods_top/goods_top1.html
Maybe you mean "EIA" code. However I mean "JIS" code.
JIS "0603" is equivalent to EIA "0201".
JIS "0402" is equivalent to EIA "01005".
JIS "0603" is 0.6mm x 0.3mm
JIS "0402" is 0.4mm x 0.2mm
As mass products,
You can get 0.01uF=10nF for JIS "0402" size.
You can get 0.47uF=470nF for JIS "0603" size.
As engineering sample, you can get 1uF=1000nF for JIS "0603" size.
http://www.yuden.co.jp/us/release/pdf/pdf_117.pdf
« Last Edit: Dec 16th, 2009, 10:08am by pancho_hideboo »
ic_engr
Reply #4 - Dec 17th, 2009, 1:32pm
Yes I meant EIA code.
Does anyone know if we can get EIA code 1005 size capacitors of 68nF at least ?
ic_engr
