Sep 27th, 2024, 1:15pm
Commerically Available Hogge Phase Detectors (Read 2264 times)
bhavuli
Dec 17th, 2009, 1:34pm
Hi Folks,
I was wondering if you would be knowing of a companies that sell hogge phase detectors.
Your help in this regard will be appreciated.
Best wishes,
bhavuli
Mayank
Re: Commerically Available Hogge Phase Detectors
Reply #1 - Dec 17th, 2009, 8:54pm
     If i am not wrong, it's mostly used in CDR circuits right ??
Check with RAMBUS, but i think they probably sell the complete IP of a CDR ckt rather than individual component IPs.
Mayank.
raja.cedt
Reply #2 - Dec 17th, 2009, 9:17pm
hi,
  rambus do compltely digital CDR, so you don't see this kind of detector. Now a dys it's hard to found that ckt. Why you want only that cell.
rajasekhar.
bhavuli
Reply #3 - Dec 18th, 2009, 5:18am
Thanks Mayank and Rajasekhar.
Yes, I am building a CDR circuit with a different approach; my circuit in addition to hogge phase detectors, makes use of ADCs, comparators, and so on. I have purchased the other chips from a company called "Analog Devices". All I have to do is put them all together on a PCB.
However, I am still trying to find a hogge phase detector or any other phase detector either digital or analog, so I don't need to spin out chip for just this.
Please help folks!
Best regards,
bhavuli
