loose-electron wrote on Dec 22nd, 2009, 9:49pm:yeah it's called an inverter...
Ha, that is what I was thinking. In addition, to line up the non-inverted signal run it through an "on" t-gate with the same sized devices as the inverter. See figure 12.18 of the
switched cap chapter of Razavi's book.
When I first saw it I figured it was an horrible hack, but it actually works well to align the clock and clock-bar signals. Not sure if it will get you 5 ps, but it is a trick worth remembering to get you close. I suppose you could trim the tgate delay by trimming the gate drive. I don't understand the PI cricuit described by analog_rf.
