Apr 19th, 2024, 5:28pm
cleaning probe tips (Read 3243 times)
oermens
cleaning probe tips
Jan 09th, 2010, 9:44pm
hello.
our lab doesn't have a kit to clean our probes. i have looked up the solutions required to remove oxide deposits from probe tips and found that NaOH and distilled water to rinse can be used, but I can not find the NaOH at any pharmacy (this is where I was told to look). Are products that contain NaOH, such as paint thinner or hair relaxers, appropriate substitutes?
I also found that isopropylalcohol can be used. Which solution does a better job?
In either case, should the solution be applied to the probe using a sponge-tipped swab, or can the be placed in something like a petri dish filled with the solution?
thanks.
