Apr 18th, 2024, 3:05pm
StrongArm Comparator Gain (Read 10609 times)
Ruritania
Canada
May 03rd, 2010, 10:50am
For the conventional StrongArm comparator (see figure attached below), we know that shortly after the rising edge of ph1, there's an amplification stage between the input (Vin+, Vin-) and output (vo+, vo-), before the regeneration takes over the operation. My question is how to simulate or predict this gain in the simulator, for example, spectre or spectreRF?
Thanks.
Re: StrongArm Comparator Gain
Reply #1 - May 3rd, 2010, 11:19am
I can't find out any design issue in your post.
Your question is no more than usage of specific vendor's simulator.
http://www.designers-guide.org/Forum/YaBB.pl?num=1245967593/2#2
analyses -> tran -> option -> actimes = 100n
acname = ac
Ruritania
Canada
Reply #2 - May 3rd, 2010, 3:25pm
pancho_hideboo wrote on May 3rd, 2010, 11:19am:
Sorry that I might have posted this at the wrong place. I supposed that people working on High speed I/O design may come across with the same issues.
acname = ac
I tried, but didn't work (the output gain is like -100dB, obviously not right). Is it because of the dynamic characteristic of this circuit?
Thanks.
Reply #3 - May 4th, 2010, 12:34am
Ruritania wrote on May 3rd, 2010, 3:25pm:
Do you set proper time for "actimes" ?
Try to vary "actimes".
You can set time array for "actimes".
actimes=[...] ; Times when analyses specified in acname array are performed.
Show me your netlist regarding signal sources and tran statement.
You must not set large signal sinusoidal for Vin+ and Vin-.
