Nov 10th, 2026, 7:59pm
OP Amp with Variable Gain (Read 4872 times)
pacej51
May 04th, 2010, 7:44am
Hi.
I am trying to implement an ideal op-amp (opamp) with a variable gain.  This gain is dependent on a bit called NINV (see code below).  If NINV is ‘0’, the gain should he +1; if NINV is ‘1’, then the gain is -1.
The code below works as intended if I simply remove the IF statement involving NINV (line 115 to 119) and set opAmpGain to the desired gain (+1.0 or -1.0).
The code, as currently shown, ignores what opAmpGain is set to at lines 116 and 118 and uses the initialized value (QUANTITY opAmpGain : REAL := 1.0;).  Is there any way to use NINV to set the op amp gain?
Thanks in advance,
Jim
BTW, “-- The DC voltage source definition begins” is line 2.
-- The DC voltage source definition begins.....
-- Schematic of the DC voltage source:
--        p o----(~)----o m a DC voltage of amplitude Value
LIBRARY DISCIPLINES;
LIBRARY IEEE;
USE DISCIPLINES.ELECTROMAGNETIC_SYSTEM.ALL;
USE IEEE.MATH_REAL.ALL;
--entity declaration.
ENTITY dcSource IS
   GENERIC (value: REAL);                  --voltage value given as generic parameters.
   PORT(TERMINAL p,m: ELECTRICAL); --Interface ports.
END;
--architecture declaration.
ARCHITECTURE behav OF dcSource IS
     --quantity declarations.
   QUANTITY v_in ACROSS i_out THROUGH p TO m;
BEGIN
      -- The DC voltage source equation.
    v_in==value; --input DC source
END;
-- The resistor definition begins.....
-- Schematic of the resistor component:
--        p o----/\/\/\----o m
ENTITY resistor IS
     GENERIC  (resistance    : REAL);            --resistance value given as a generic parameter.
   PORT     (TERMINAL p,m  : ELECTRICAL);      --Interface ports.
END resistor;
ARCHITECTURE behav OF resistor IS
   QUANTITY r_e ACROSS r_i THROUGH p TO m;
BEGIN
   r_i == r_e/resistance; -- The ohmic resistance equation.
END behav;
--ideal operation  amplifier
--               _____________
--      p o---|--------|     \
--      m o---|--|     |      \
--              |  <     <         \ __ o a
--              |  < r1  < r2         /
--              |  <     <        /       u_a = (U1-U2) * value
--              |  |_____|       /
--              |________o___      /       o
--                          --- gnd         --- gnd
ENTITY opv IS
   GENERIC (value,r_in_minus,r_in_plus    : REAL);          --generic parameters.
   PORT    (TERMINAL p,m,a                : ELECTRICAL);    --Interface ports.
END;
ARCHITECTURE behav OF opv IS
   QUANTITY u_1 ACROSS i_1 THROUGH     p TO electrical_ground;
   QUANTITY u_2 ACROSS i_2 THROUGH     m TO electrical_ground;
   QUANTITY u_out ACROSS i_out THROUGH a TO electrical_ground;
BEGIN
   i_1==u_1/r_in_minus;
   i_2==u_2/r_in_plus;
   u_out ==(u_1-u_2) * value;
END;
-- testbench
ENTITY network IS
END;
ARCHITECTURE behav OF network IS
   TERMINAL n1: ELECTRICAL;
   TERMINAL n2: ELECTRICAL;
   TERMINAL n3: ELECTRICAL;
   TERMINAL n4: ELECTRICAL;
     CONSTANT NINV            : BIT := '1';
BEGIN
     -- Input
   vin  : ENTITY dcSource       (behav)  GENERIC MAP (3.0)                        PORT MAP (n1, electrical_ground);
     -- Series Resistors
     r1      : ENTITY resistor            (behav)  GENERIC MAP (4.0e3)                        PORT MAP (n1,n2);
     r2      : ENTITY resistor            (behav)  GENERIC MAP (4.0e3)                        PORT MAP (n3,electrical_ground);
     -- GF Amp
     if  NINV = '1' use
       opAmpGain == -2.0;
     else
           opAmpGain == 2.0;
     end use;
   opamp    : ENTITY opv              (behav)  GENERIC MAP (1.0*opAmpGain, 1.0e6, 1.0e6)    PORT MAP (n2,n3,n4);
END;
boe
Re: OP Amp with Variable Gain
Reply #1 - Jul 9th, 2010, 1:17am
My vendor tool dokumentation states Quote:
A generic is a constant in the interface of an entity.
You need to use a port.
BOE
