Sep 27th, 2024, 4:28pm
Looking for study report on 128b/130b coding (Read 4915 times)
neoflash
Mixed-Signal
Designer
Jul 29th, 2010, 5:45pm
PCI-E is adopting 128/130 coding to replace 8b/10b encoding.
I'm looking for materials studying the code performance, such as transition density, DC balancing, maximum run length...
Thanks for the sharing of the information.
Neo
supermoment
Re: Looking for study report on 128b/130b coding
Reply #1 - Jul 30th, 2010, 12:40am
I think the similar theories of 8B10B may be applied to 128B/130B to achieve dc balance. The 2 preamble bits is used as sync payload.
But the max run length / data density depends on data scrambler.
That means the CDR will be more challenging! It has more DC wander, thus it needs larger CDR bandwidth (around 5-10MHz).
On the other hand to reduce jitter (clk), Tx/Rx PLL bandwidth must be reduced.
