Jun 1st, 2023, 3:59pm
Link a netlist to a layout for LVS and simulation (Read 12004 times)
aaron_do
Aug 23rd, 2010, 8:42pm
this is related to my previous topic, but I want to ask this separately just to avoid any confusion. Basically I have created a SPICE netlist of a center-tapped inductor using ADS. The netlist is shown below (the file name is 3_PORT.cir)
I originally did the layout of the inductor in Virtuoso, and now I want to link this netlist to a symbol and the layout so that I can use this inductor as if it were an inductor from my PDK...i.e. it should be able to pass LVS, and be instantiated in a schematic for simulation in ADE. So how do I do this? The best I could find is the link below,
http://www.cadence.com/Community/blogs/rf/archive/2009/01/07/tip-of-the-week-how...
but i'm not sure that its relevant. Anyway I couldn't get it to work. Can anyone please tell me how I can get this done? I don't believe it is that difficult...
Note that this netlist is quite simple. I'll generate a more accurate one if necessary later...
thanks,
Aaron
Quote:
SPICE 2G6 netlist generated from [S] parameters
.subckt 3_PORT 1 2 3
* L in nH, C in pF
R1  1  0  5755.04888704202
C1  1  0  0.0216441537364164P
C2  1  2  0.254276980705922P
R2  2  0  5916.61612055921
C3  2  0  0.0209698166681806P
R3  3  0  27976.2145075654
C4  3  0  0.032643729681058P
R4  1  6  3.51165320272679
L1  6  3  0.458570933771721N
R5  2  8  3.56845501963307
L2  8  3  0.462151170377161N
.ENDS
* end of sub-circuit
btw here is the error I got when I tried to use the method in the link.
Quote:
sevNetlistAndRun('sevSession1)
Delete psf data in /usr2/tmp/PowerGain_diff/spectre/schematic/psf.
generate netlist...
Begin Incremental Netlisting Aug 24 11:41:37 2010
*Error* ilGetString: arg must be symbol or string - 1
<<< Stack Trace >>>
(... in nlPrintInstSignals ...)
(... in nlPrintInst ...)
(... in _nlPrintInstInContext ...)
(... in nlNetlistFileInstOutput ...)
apply('nlNetlistFileInstOutput _artAliasArg_)
(... in hnlProcInst ...)
hnlProcInst('(db:0xb77333a0 db:0xb4b75992 0 1 ("net077" "net076" "net075") ... ))
(... in hnlPrintDevices ...)
hnlPrintDevices()
(... in hnlPrintMacroCell ...)
hnlPrintMacroCell()
skillEvalString("hnlPrintMacroCell()" nil)
(... in hnlDoInstBased ...)
(... in hnlPrintNetlist ...)
(... in hnlRunForkedNetlister ...)
hnlRunForkedNetlister()
skillEvalString("hnlRunForkedNetlister" nil)
ERROR (ADE-6026): Unable to create the netlist due to failure of following operating system command(s)
      "sh: ./.control: Text file busy"
      Contact your system administrator for assistance.
     ...unsuccessful.
Tawna Wilsey
Snohomish, WA
Re: Link a netlist to a layout for LVS and simulation
Reply #1 - Aug 24th, 2010, 11:30am
Hi Aaron,
This is a super quick reply, as I'm in the middle of a project...
This error you are seeing typically indicates that there is an issue with the CDF.
I am assuming that you are using IC6.1.4 (as opposed to 5.1.41).
I created a netlist using your inductor snippet -- see below.  (I put it in a format so I could easily simulate in spectre):
simulator lang=spectre
subckt three_port 1 2 3
simulator lang=spice
* L in nH, C in pF
ends three_port
I edited the CDF as noted in the link
http://www.cadence.com/Community/blogs/rf/archive/2009/01/07/tip-of-the-week-how....
(Note:  this was written for IC5.1.41 but the basic idea is the same)
Here is a snippet (not the complete) CDF for the inductor symbol:
LIBRARY = "testcase"
CELL    = "Aaron_inductor"
let( ( libId cellId cdfId )
   unless( cellId = ddGetObj( LIBRARY CELL )
       error( "Could not get cell %s." CELL )
   when( cdfId = cdfGetBaseCellCDF( cellId )
       cdfDeleteCDF( cdfId )
   cdfId  = cdfCreateBaseCellCDF( cellId )
   ;;; Parameters
   cdfCreateParam( cdfId
       ?name           "model"
       ?prompt         "model name"
       ?defValue       ""
       ?type           "string"
       ?parseAsCEL     "yes"
   ;;; Simulator Information
cdfId->simInfo->spectre = '( nil
       modelParamExprList nil
       optParamExprList  nil
       opParamExprList   nil
       stringParameters  nil
       propMapping       nil
       termMapping       nil
       termOrder         ("1" "2" "3")
       componentName     nil
       instParameters    (myParameters)
       otherParameters   (model)
       netlistProcedure  nil
   ;;; Properties
   cdfId->formInitProc            = ""
   cdfId->doneProc                = ""
   cdfId->buttonFieldWidth        = 340
   cdfId->fieldHeight             = 35
   cdfId->fieldWidth              = 350
   cdfId->promptWidth             = 175
   cdfId->instNameType            = "schematic"
   cdfId->instDisplayMode         = "instName"
   cdfId->netNameType             = "schematic"
   cdfId->termSimType             = "DC"
   cdfId->termDisplayMode         = "netName"
   cdfId->paramSimType            = "DC"
   cdfId->paramDisplayMode        = "parameter"
   cdfSaveCDF( cdfId )
I was able to instantiate the inductor subckt in the schematic and run an sp simulation.
If you continue to have issues with this, please contact Cadence Customer Support ( support.cadence.com ) so we can help you out.
best rgards,
Tawna Wilsey
Cadence Design Systems
Tawna Wilsey
View Profile tawnaWilsey   IP Logged
Tawna Wilsey
Snohomish, WA
Reply #2 - Aug 24th, 2010, 11:38am
Hi Aaron,
One more thing...the error message  (Error ADE-6026) that you get is pretty cryptic and doesn't point the real issue.  It should point you to issues in the CDF rather than spit out:
    ...unsuccessful.
Please contact Cadence Customer Support ( support.cadence.com ) so we can file a CCR on your behalf to have the error message improved.
best regards,
Tawna Wilsey
Cadence
Tawna Wilsey
aaron_do
Reply #3 - Aug 24th, 2010, 5:32pm
Hi Tawna,
thanks for the reply. I'm not really sure exactly what I should do at this point, however. I suppose I can try and redo the CDF editing and see if I got any of the parameters wrong. But my main concern is really how can I link a schematic to a layout so that it passes LVS? If I simply create a schematic of the netlist, and then draw the inductor, it will fail LVS because the schematic looks nothing like the layout.
Any help is appreciated,
thanks,
Aaron
Tawna Wilsey
Snohomish, WA
Reply #4 - Aug 24th, 2010, 5:35pm
Hi Aaron,
RE: what to do ....
I recommend contacting Cadence Customer Support ( support.cadence.com ) for your question.  I can help you with the front end (simulation/netlisting) questions.  I just don't have a lot of experience with the LVS part.
best regards,
Tawna Wilsey
Cadence
Tawna Wilsey
