Apr 25th, 2024, 6:14am
Difference between SERDES, SGMII, 1000BASE-X ? (Read 9506 times)
gavin
Canada
Sep 23rd, 2010, 6:25am
Hello:
Can someone help clarify the difference between SERDES, SGMII & 1000BASE-X?
Gavin
Re: Difference between SERDES, SGMII, 1000BASE-X ?
Reply #1 - Sep 24th, 2010, 3:00pm
"SERDES" (Serializer Deserializer) is a global statement of a circuit function. - Generally means take parallel data, convert to serial data, send it over a transmission medium (ofter wires, but not always) and receive it and process back to parallel data.
Many devices (some of what you mention) use SerDes structures, USB1,2,3, Ethernet, Firewire (and many others) have SerDes structures within them. However, they differ in data rates, encoding, compensation methods, etc, etc.
