omar
I'm working with verilog-a compact models in spectre. I am wondering if there is a way to create a module such that I can change parameters in the module without opening the code. For example, when we're working with the compact model of a transistor, it would be really helpful to change the width in each simulation without having to open the verilog-a code each time.
