Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Apr 23
rd
, 2024, 2:38pm
Home
Help
Search
Login
Register
PM to admin
Measurements
RF Measurements
› PLL BW measurement
Previous topic
Next topic
PLL BW measurement (Read 5995 times)
raja.cedt
PLL BW measurement
Nov 08
th
, 2010, 5:16am
hi, can any please tell me how to find BW in silicon
I know that Intersecting point of VCO phase noise and pll phase noise point is almost BW. Is this exact method or can any one please explain often how people measures?
Thanks.
IP Logged
Mayank
Re: PLL BW measurement
Reply #1 -
Nov 19
th
, 2010, 5:22am
approximately, yes.
You could tell by pll phase noise graph itself in most of the cases.
IP Logged
raja.cedt
Reply #2 -
Nov 19
th
, 2010, 6:22am
hi mayank,
how can you say from overal PLL phase noise. I htink from where phase noise start falling (means the boundary between inband and outoff band noise), do you have any document for this
Thanks.
IP Logged
love_analog
Reply #3 -
Mar 3
rd
, 2011, 2:04pm
To measure PLL BW, you put a refclock with a modulated sinewave input. So you are modulating the phase of the input refclock. Then you look at the output on the spectrum analyzer. You should see a spur at the same frequency as the phase modulation. The measure of the spur compared to the input refclock spur gives you a value for the attenuation. At att=-3db is where PLL BW is.
loveanalog.blogspot.com
The Power of Analog
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
»» RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
