Mar 28th, 2023, 5:22am
What ir the error while implementing the code on HAMSTER (Read 4017 times)
Ashish_Shavarna
Nov 12th, 2010, 4:10am
SAW Device Package
LIBRARY DISCIPLINES;
LIBRARY IEEE;
USE DISCIPLINES.ELECTROMAGNETIC_SYSTEM.ALL;
USE IEEE.MATH_REAL.ALL;
ENTITY SAW IS
   PORT(TERMINAL i,o : ELECTRICAL);--Interface ports.
END SAW;
ARCHITECTURE behav OF SAW IS
   QUANTITY v_in ACROSS i;
     QUANTITY v_out ACROSS i_out THROUGH o;
     QUANTITY Z,X,H,HT: REAL;
     CONSTANT F0: REAL := 225.571e6;
     CONSTANT Np: REAL := 226;
     CONSTANT Cs: REAL := 0.503385e-12;
     CONSTANT K: REAL :=0.04;
BEGIN
     X == 1.0e-12 when now=F0 else 3.14*Np*((now-F0)/F0);
     v_out == v_in*2.0*K*sqrt(Cs*F0)*Np*((sin (X))/X);
     Z == 2.0*K*sqrt(Cs*f0)*Np*(sin (1.0e-12)/(1.0e-12));
     HT == 20.0*log10(abs(v_out**2.0)/(z**2.0));
END ARCHITECTURE behav;
-- The resistor definition begins.....
-- Schematic of the resistor component:
--        p o----/\/\/\----o m
ENTITY resistor IS
     GENERIC  (resistance    : REAL);            --resistance value given as a generic parameter.
   PORT     (TERMINAL p,m  : ELECTRICAL);      --Interface ports.
END resistor;
ARCHITECTURE behav OF resistor IS
   QUANTITY r_e ACROSS r_i THROUGH p TO m;
BEGIN
   r_i == r_e/resistance;  -- The ohmic resistance equation.
END behav;
--Impulse Source
LIBRARY IEEE;
ENTITY vsource IS
   PORT(TERMINAL p,m: ELECTRICAL); --Interface ports.
END;
ARCHITECTURE behav OF source IS
     --quantity declarations.
   QUANTITY v_in ACROSS i_in THROUGH p TO m;
BEGIN
     v_in == 1.0;
END;
-- Test Bench
ENTITY network IS
END;
ARCHITECTURE behav OF network IS
     TERMINAL n1,n2,n3,n4,n5: ELECTRICAL;
BEGIN
     VS          : ENTITY vsource    (behav)                    PORT MAP (n1, electrical_ground);
     SAW_device  : ENTITY SAW        (behav)                    PORT MAP (n2,n3);
     R1                : ENTITY Resistor   (behav) GENERIC MAP (50.0) PORT MAP (n1,n2);
     R2                : ENTITY Resistor   (behav) GENERIC MAP (50.0) PORT MAP (n3,electrical_ground);
END;
I have this error " Unexpected Identifier : IDNETIFIER SAW"
Please help, otherwise i may lose my job!!
