Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Apr 25
th
, 2024, 3:22am
Home
Help
Search
Login
Register
PM to admin
Simulators
Circuit Simulators
› Measuring distortion of a bootstrapped switch
Previous topic
Next topic
Measuring distortion of a bootstrapped switch (Read 3764 times)
Nandish Mehta
Feb 20
th
, 2011, 9:48am
Hello Friends,
I am designing a low voltage boot strapped switch.
Can any one please suggest me method to measure the distortion of that switch? I am using SPECTRE as circuit simulator.
Any inputs or suggestions will be highly appreciated
Nandish
IP Logged
Re: Measuring distortion of a bootstrapped switch
Reply #1 -
Mar 2
nd
, 2011, 6:50am
Hi Nandish,
Run transient simulation and do FFT.
IP Logged
Nandish Mehta
Reply #2 -
Mar 2
nd
, 2011, 9:11am
Hi ywguo,
Sorry for asking such silly question but I am a newbie to design of analog ckts.
I later found out that to measure distortion of boot strap switch I need to do DFT.
However, when I designed the respective test bench I am getting another error. The single tone sinusoid in my test bench is shown as a spread of frequency in my DFT.
My simulations setting information is as below:
1) Input is from ideal sinusiodal voltage source with 3 MHz freq.
2) Sampling frequency for sample and hold is 20 MHz
3) Simulation is ran for 10us
4) 1024 point DFT is calculated with rectangular window
With this issue I cannot rely on the DFT for giving me accurate distortion value. Please suggest me some solution if you know.
Nandish
Nandish
IP Logged
Reply #3 -
Mar 7
th
, 2011, 1:04am
Hi Nandish,
Obviously you did not run the bootstrapped switch with coherent sampling. Try to search "coherent sampling" in this forum and google "coherent sampling", you could get a lot of useful message.
Yawei
IP Logged
Frank Wiedmann
Munich, Germany
Reply #4 -
Mar 7
th
, 2011, 8:19am
This is exactly the subject of the link I gave him at
http://www.designers-guide.org/Forum/YaBB.pl?num=1298281879/3#3
. Seems like he did not understand it...
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
»» Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
