Oct 16th, 2026, 3:29am
distributed interconnect paramter calculation in cadence (Read 10597 times)
sujeetkumarmehta
nagpur
Feb 22nd, 2011, 1:04pm
I wanted to know how to define distributed transmission line parameter  in cadence ?  can it be done with mt line ?
Larry_80
Re: distributed interconnect paramter calculation in cadence
Reply #1 - Aug 16th, 2011, 8:32pm
why don't u just use the transmission line equivalent models i.e L R and C if you have them?
rfcooltools.com
Reply #2 - Sep 7th, 2011, 5:18pm
sujeetkumarmehta,
if you have a single line use the tline in the analog lib.  There are more entries in the form than needed to make the model work.  Typically I just enter characteristic impedance and length.  The same applies to the mtline.
http://rfcooltools.com
Reply #3 - Oct 29th, 2011, 5:08pm
consider the possiblitity of lumped elements in a cascaded chain. Frequently this is more accurate than doing the transmission line model.
