It's a pretty classical issue.
(one of those you don't find in the text book).
Generally you hope most block control lines are immune to start up conditions, but inevitably there are a few sticklers.
PD, IDDQ, select lines, etc.
You can run your PoR signal in and give it a reset.
You have to look at your power, regulator turn on sequences carefully.
Wave
