Aug 31st, 2024, 1:22pm
DETERMINING POLARITY OF FEEDBACK OF A CIRCUIT (Read 4605 times)
Larry_80
Aug 03rd, 2011, 4:00pm
hello Guys,
I am having trouble on how to determine the polarity of feedback of a circuit. I have attached 2 circuits that i need explanation of. Basically, with an emphasis on explaining to me why an increase in current will cause deduction in drain voltage for example especially in cases where the Load is a current source.
AnalogDE
Re: DETERMINING POLARITY OF FEEDBACK OF A CIRCUIT
Reply #1 - Aug 3rd, 2011, 5:33pm
Both look like negative feedback to me.
You need to be more clear on your second question -- which current and which drain?
Larry_80
Reply #2 - Aug 3rd, 2011, 5:59pm
For example for circuit a.) I was trying to find out the polarity, and this was how i went through it...
Vin increases, Id1 increases, id2 reduces,this makes Vd2 increase?, since vd2 is connected to gate of M3(PMOS), this makes Id3 reduce?, reduction in id3 means drop across R1 reduces as a result vout reduces which makes Id2 reduce=> Positive feedback. I might be doing something wrong somewhere as u said it was negative feedback.
aaron_do
Reply #3 - Aug 3rd, 2011, 6:33pm
where did you get the circuit from?
You weren't doing anything incorrect...the first example is positive feedback.
regards,
Aaron
Larry_80
Reply #4 - Aug 3rd, 2011, 6:37pm
I got the circuit from Razavi Fundamental of microelectronics. I am just trying to go back to the basics and really understand some of the fundamentals easily overlooked.
buddypoor
Bremen, Germany
Reply #5 - Aug 4th, 2011, 12:54am
Yes, the first circuit has positive and the second circuit has negative feedback.
AnalogDE
Reply #6 - Aug 4th, 2011, 8:32am
My bad, the first one is indeed positive feedback.
It's simple to look at it in terms of voltages.  Let's assume the output moves up in voltage for some reason -- the NMOS M2 gate increases, pulling its drain node down, which increases Vgs of PMOS M3, turning it on harder, which pulls its drain up => feedback acts to enforce the voltage change on the output node => this is positive feedback.
