Aug 31st, 2024, 7:19am
Typical Power supply value for 0.18um Technology for TransImpedance Amplifier (Read 2731 times)
Larry_80
Aug 03rd, 2011, 7:19pm
Hello All,
Could someone pls tell me the typical VDD value for a highspeed >2.5GHz transimpedance amplifier(Inductor free)? I am embarking on a self project and want to make sure i am using typical value for my power supply. Is 2V an OK value?
May i add also what a typical value for the input diode capacitance might be.
aaron_do
Re: Typical Power supply value for 0.18um Technology for TransImpedance Amplifier
Reply #1 - Aug 3rd, 2011, 8:08pm
Its mainly determined by the stress that the devices can handle. I think 0.18 um technology is typically 1.8 V and 3.3 V for high voltage devices. 2 V may cause long term stress issues especially for digital circuits.
Not sure about input diode capacitance...probably need to check some publications, or if possible, manufacturer data.
regards,
Aaron
Reply #2 - Aug 4th, 2011, 7:06am
input diode capacitance will be tightly tied to ESD capabilities. need to check for specifics of I/O cells.
