Apr 19th, 2024, 12:30am
Choosing correct load capacitor for SC DC DC Buck converter (Read 7598 times)
Vabzter
Sweden
Sep 05th, 2011, 11:17pm
Hello all,
             I am designing a Buck DC DC Switch cap converter for 3.3 Vin and 1.8 Vout, load current 10mA. Can anyone give me some references detailing the relation between charge transfer capacitors and load capacitor?
            From one IEEE paper it was mentioned that the load capacitor directly affects the output ripple for a particular switching frequency. But is there any relation of Cl with load current, charge transfer caps and any other parameters?
Thank you for your help,
Vab
Re: Choosing correct load capacitor for SC DC DC Buck converter
Reply #1 - Sep 14th, 2011, 12:19pm
Suggest - get out of the IEEE papers and go read some of the industry papers out there on these types of converters. Intersil and others have writeups on how to select these components for their versions of these converters.
Application notes on these products will have writeups.
Vabzter
Sweden
Reply #2 - Sep 14th, 2011, 7:33pm
Thanks for your suggestions..
Reply #3 - Sep 18th, 2011, 1:41pm
Not  a problem. The IEEE is often not the most useful source of information.
Even though I am a chapter chair for the IEEE and I review for the MTT and SSC journals, I generally see that the material that is "practical" never ends up in the IEEE publications.
Arie Aandewiel
2 Sun Ct, Norcross, GA 30092
Reply #4 - Sep 19th, 2011, 12:27am
loose-electron wrote on Sep 14th, 2011, 12:19pm:
Could you able to provide any IEEE paper in through this post? Thanks in advance.
View Profile Arie+A+Aandewiel Arie+A+Aandewiel   IP Logged
Reply #5 - Oct 1st, 2011, 2:59pm
I am not sure what you are asking for. I am saying go read the application notes from industry manufacturers of these products.
Google search!
