Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Sep 27
th
, 2024, 3:07am
Home
Help
Search
Login
Register
PM to admin
Design Languages
Verilog-AMS
› HOw to declare a bit
Previous topic
Next topic
HOw to declare a bit (Read 2280 times)
zahrein
Sep 29
th
, 2011, 12:04am
Hi
Is this how you declare a bit?
real d_enable =1b'1;
CODE
module measure_voh_vol (pad,data);
input pad;
//input d_enable;
input data;
parameter real voh=0.9;
parameter real vol=0.3;
IP Logged
Re: HOw to declare a bit
Reply #1 -
Oct 7
th
, 2011, 7:42am
Without thinking too hard about it, I would have said
integer d_enable = 1b'1;
IP Logged
boe
Reply #2 -
Oct 7
th
, 2011, 8:08am
In Verilog(-AMS) integers are (at least) 32 bit wide. If you want a single bit you should use a reg/wire.
-B O E
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
»» Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
