Raja,
Usually, you only need to set noisefmax when simulating white noise and noisefmax/noisefmin when simulating 1/f and white noise.
a. Noise seed, seed for the noise generator, not really required b. Noise fmax, sets the maximum frequency of the noise c. Noise scale, probably not required. scales the noise up to reduce the effect of numerical noise on the calculation d. Noise fmin, used if you want to model 1/f noise, sets the minimum frequency for the 1/f noise generator e. Noise tmin, the inverse of noisefmax, sets the minimum time step size
