Sep 26th, 2024, 10:14pm
LDO with buffer (Read 8352 times)
grosser
LDO with buffer
Oct 26th, 2011, 1:17pm
Hello
I wonder about using single stage opamp with unity gain buffer, but to achieve PM>60deg i need to lower amplifier's gain because the system is unstable in other case. Low current amplifier => smal transistors area => more offset => lower accuracy
Low gain influences load regulation badly.
What kind of amplifer do you use with unity gain buffer ? or what kind of buffer can i use. i tried source follower but the result is almost the same.
The second thing is, how ultra low quiescent current (1uA) LDOs are designed. The bandgap, amplifier, voltage divider consume current. How it's possible to make it so low and get quite resonable results?
kind regards
grosser
rajkumar palwai
Sunnyvale, California
Re: LDO with buffer
Reply #1 - Oct 26th, 2011, 10:10pm
Hi Grosser,
In all of the ultra low quiescent amplifiers, transistors are biased in sub-threshold and deep-subthreshold regions. In sub-threshold regions transistors are huge, currents are ultra-low and mosfets get highest gm's.
I dont understand why are u getting stablity problems by using a single stage amplifier. I dont see 2 poles here and hence the system should be stable.
rajkumar
grosser
Re: LDO with buffer
Reply #2 - Oct 27th, 2011, 12:55am
rajkumar palwai wrote on Oct 26th, 2011, 10:10pm:
rajkumar
Using one stage OTA biased at 1u for instance I cannot drive huge PMOS well. PM is very low then.
So I added the unity gain buffer to move dominant pole to higher freqs. Higher gain and pole movement makes the GBW 2 or 3MHz but the PM is still low for higher loads because of parasitics.
raja.cedt
Re: LDO with buffer
Reply #3 - Oct 27th, 2011, 1:01am
hello grosser,
is it an opamp or LDO (means single stage opamp and pass device), because you are talking about load current, so i am assuming that it's an LDo. So it's quite common to get stability problems. If you are using single stage opamp and still want to draw current better use some class AB stage.
@rajkumar: raj, i think because of two stage, he may get stability problem.
Raj.
grosser
Re: LDO with buffer
Reply #4 - Oct 27th, 2011, 1:42am
raja.cedt wrote on Oct 27th, 2011, 1:01am:
hello grosser,
Raj.
Yes it's LDO design as the subject states.
I know stability problems, but want to know how to mix high gain amplifier >60dB with buffer and get PM>60. Everything with low currents <10uA overall
raja.cedt
Re: LDO with buffer
Reply #5 - Oct 27th, 2011, 1:54am
hello man,
i didn't understand term how ''to mix'', please remeber that gain and phase margin are not trade off you can any amount of gain for any decent phase margin..
Raj.
grosser
Re: LDO with buffer
Reply #6 - Oct 27th, 2011, 4:19am
raja.cedt wrote on Oct 27th, 2011, 1:54am:
hello man,
Raj.
well, writting "to mix" i meant using high gain ota + buffer
no. i can't have any amount of gain with decent PM.
using high gain low current ota wit huge pass device you can't satisfy PM without compensation or buffering.
i'm asking for a clear advice regarding ota + buffer architecture, not "LDOs  for dummies"
surely someone already did that.
Praveen K
Bangalore
Re: LDO with buffer
Reply #7 - Oct 27th, 2011, 5:33am
Hi grosser,
you are adding a buffer here to drive the huge PMOS pass transistor, but anyway you are restricted by the power dissipation i.e. < 10uA.
why not you burn that in the OTA itself?
in PM point of view, this buffer is moving your dominant pole to higher frequency and hence worsens the phase margin. A buffer like this will only help, when the dominant pole is at the output of LDO( at drain of PMOS pass transistor).
my suggestion is, telescopic OTA ( burn the buffer current here itself), followed by PMOS pass and use miller cap through the cascode node of telescopic.
what say  ;)
k.praveen
View Profile praveenjthomas   IP Logged
Re: LDO with buffer
Reply #8 - Oct 27th, 2011, 4:54pm
typically you want to use an OTA to drive the pass transistor.
sounds like you are using an op-amp structure?
grosser
Re: LDO with buffer
Reply #9 - Oct 28th, 2011, 1:20am
loose-electron wrote on Oct 27th, 2011, 4:54pm:
yes, but as low impedance output I use unity gain buffer
analog_wiz
Universe
Re: LDO with buffer
Reply #10 - Nov 20th, 2012, 2:52am
Grosser, can you post a pic of the arch you are trying to design. I have implemented some of these and can help you out.Standard LDO design topologies (according to me):
1. Differential to single ended stage followed by output stage which consists of a pass device sized to deliver current as per load current requirements.
2.Stb is entirely dependent on where your poles are. If your output pole is dominant then you will end up having movement of your dominant pole with load current (does the non dominant pole also vary:find out?)
3.Assume LDO is internally stabilized: then your worst case stability condition will arise when ILoad=0mA.In this case dominant pole is the standard pole due to miller cap due to pass device and the output pole is the gmpass/Cload+Cgd. You can burn very low current at the expense of being very noisy as well as at using up lot of area for your resistors(high res to due to low quiscent current). So if yours is not a noise critical application then you can maybe get away with burning very less current also.
More info once you let us know the application you are designing for... Smiley
Lex
Eindhoven, Holland
Re: LDO with buffer
Reply #11 - Nov 20th, 2012, 5:37am
grosser wrote on Oct 26th, 2011, 1:17pm:
  • What kind of accuracy/PSRR are you looking for? What is the Iload(min) and Iload(max)?
  • "Lower current =>small transistor area" is not correct. Lower current => lower W/L.
  • Stability problems? Where are the poles and what kind of frequency compensation are you applying?
