I'm sorry I did not explain this question clearly.
if we have two clocks, their output amplitudes are different(eg. one is 1V and another is 2V) but the phase noise are the same(eg. -100dBc/Hz@10K, -120dBc/Hz@100K, -150dBc/Hz@1M).
then we use these two clock as two PLL's reference respectively, the other part of these two PLL are the same to each other.
how about these two PLL output phase noise? (same or different?)
Thanks for your time~
