Apr 24th, 2024, 9:12pm
Wide Band BALUN (50MHz to 3GHz) (Read 4346 times)
Ricky Chen
Jan 11th, 2012, 6:56am
Dear All,
I am looking for wideband 50MHz - 3GHz balun Module for measuring the Test chip. ( Multi-Band multiple baluns can still be OK ). The chip is a full receiver. The input to the LNA is fully differntial ( 50-Ohm i/p differential impedance)  but my VNA and other measuring equipments are single-ended.
I am going to measure by Wafer probing NOT on PCB.
So I need balun which will convert the measuring instruments single-ended signal to differential and give it to the PROBE which is connected to DUT (Test Chip)  .
Can anybody suggest some wid-band baluns ( with good Balance ) available ?
Re: Wide Band BALUN (50MHz to 3GHz)
Reply #1 - Jun 16th, 2012, 6:36am
I don't know what interface you need. But mini-circuits produces a lot of good baluns.
Yawei
biff44
Reply #2 - Jul 8th, 2012, 2:05pm
Marki and Picosecond Pulse labs both produce good connectorized baluns.  They have excellent 180 deg phase tracking, good gain tracking, and fair return loss.
