Apr 19th, 2024, 6:14am
Different delays in RO-VCO stages? (Read 2731 times)
AS
US
Jan 27th, 2012, 2:08pm
What happens to the spectral purity of a ring oscillator with different delays for each stage? My understanding is that even for a highly linearized SS model staggered poles will lead to a much wider frequency spread to achieve the avg. 360 phase shift; hence higher Jitter/Pnoise. This can also be explained if we start looking at the non-linear limit cycle behavior; the trajectory might still be stable e.g. Demir; but the boundary will be spread (chaotic) even if we ignore internal noise of the devices. If I'm correct is there a way to demonstrate this using HB-PSS?
raja.cedt
Re: Different delays in RO-VCO stages?
Reply #1 - Jan 28th, 2012, 2:21am
could you please explain better....i didn't understand most of the temrs like SS..
Raj.
